Next project (one of 5 for this customer!).
An armpod with armboards for a Fidelity Research FR64s and AS Aquila tonearms.
Here are the pics under construction so far.
Cast lead filled for good mass, ebony armboards and adjustable knurled brass feet (this time with composite cones).
Feet
Machining the armboards
Machining the armpod tube
Machining the armbase and arm pillar fitting
Trial fitting the armboards
Armboards and tube (unfinished)
Armboards ready for mounting drillings
Armtube filled, fine rubbed down and priming before satin black lacquer is applied
Sent from my Pixel XL using Tapatalk
