WANTED! 90 DEGREE Right-Angle 5-Pin Tonearm DIN Converter
Lads! Need a spot of help. I looking for a 90 degree right angled 5-pin tonearm din converter I'm fitting a SME V 12 to my new tonearm board but the tonearm
cable connection is snagging on the underside of the tonearm board. Fitting the cable isn't a problem, it's when I try and raise the height of the whole tone-arm. Things are getting snagged so I need a converter that I can plug into the tonearm cable connector into the SME V then enabling the tonearm cable to sit at 9 degrees and allow the whole tonearm's vertical height to be adjusted. I hope this makes sense. I'll probably get the tonearm cable reterminated after Xmas but I just want something to put me on.
Thanks
Andy
