Results 1 to 3 of 3
Thread: Can I add the TT PSU to my RP3?
    I'm Russell.
    Default Can I add the TT PSU to my RP3?
    Am thinking of going down the upgrade path on my RP3 and was thinking of adding the offboard PSU but not sure I can on mine?
    Not sure which variant it is as there's so many but I've taken photo's below to help identification.
    When I take the cover off the motor, the mains lead is connected directly so not sure how / if I could add Rega's TT PSU to this?
    Any advice would be appreciated.
    I'm Russell.
    Noted this is the P3, not RP3 therefore I need the 24v Motor upgrade first.
    You do need the 24v motor upgrade kit and this will give at least as much of an improvement to the sound as does the power supply.
    Do you have the blue spacer fitted to the front cartridge screw ? Also, my OCD is kicking in as you have the bolts pointing down instead of up. Nuts on top with a Rega arm.
