Originally Posted by
AJSki2fly
Is this with the right angle tonearm cable? If it is and the cartridge down at the rear then be careful with warped records if you have any, best to get a one with a straight DIN if you intend to use long term.
Yes it is, only using it until I buy a straight one, so just a few days. The bass is overwhelming at the minute, and the sound is a bit raw, so may'be correct tonearm height will correct that, it is down a fair bit at the back, still listenable though.
