Results 1 to 4 of 4
Thread: Valve test favour needed.....
    Default Valve test favour needed.....
    I'm trying to get a quad of GEC KT88's. I've got two and need them testing. I wondered if anyone in the community would be kind enough to test them for me?
    Here's hoping...
    PRE
    I would but for the next few months I've gone down the psycho rabbit hole to get them, 100% calibrated. Jeez it's a struggle, and I hope worth while, time will tell. All good luck in your quest
    Hi Andy,
    Send a PM to AnthonyTD... He'll do it for you no problem on his professional valve tester, and if you ask him nicely he might even have another two, for you to make your quad!
    Thanks.
    PRE
