As per the title, looking for a few if anyone has some they want to part with?
Will also consider their other options for AC, USB, E-Tuning etc.
https://www.akikoaudio.com/en/akiko-...io-accessories
What do they do?
Blimey !! ....
Uses:
- Connected to the speaker cables with the accompanying Velcro strap. When connected as close as possible to the ends, the Tuning Stick Universal will clearly improve the sound. It will definitely be an upgrade for your speaker cables. Even the best and most expensive cables will sound better.
By now this model is used in shows and exhibitions by leading speaker cable manufactures.
- Connected to the analogue interlink with the accompanying Velcro strap.
- Connected to the digital (coaxial) interlink with the accompanying Velcro strap.
- Connected to the UTP data cable with the accompanying Velcro strap. Contrary to popular belief, data cables can be improved. After all power is needed to transport digital information and by enhancing that power supply the sound will always be improved.
- Connected to the power cable. This use is very special, as the effect is different to placing our E-Tuning Gold, which has been developed especially for power cords. The Tuning Stick Universal causes a clean and fine sound with a lot of dimensionality, while the E-tuning Gold delivers a more analogue and 'warm' rendering.
- Connected to the rear side of your equipment with the accompanying Velcro strap.
- Placed in the electricity meter cupboard, close to the network of your audio setup. Don't forget the white grounding cable, the Tuning Stick can really surprise you here.
- Placed on the rear side of your television. Connect it to the antenna cables of your cable and satellite TV with the Velcro strap.
As you can see the name 'Universal' was not arbitrarily chosen. The Tuning Stick Universal is an accessory which invites you to experiment. Because of the elegant, yet at the same time handy, design, the Tuning Stick can be placed inconspicuously in each set.
"lack of passion is fatal"
Not sure I understand, they seem to have plugs but it says attach them to a cable with a Velcro strap... Do the plugs just dangle in space then??
Please do not clutter a legitimate 'Private Exhibitions' request for items with posts that are not a direct reply. Thanks chaps.
