Maybe some like 'ruined sound'. Response anomalies can appeal....for the wrong reasons.
I'm Deleted.
I agree, the CM isolator is a fundamentally flawed product and any system fitted with one can be improved by removing it!
Account Deleted
I’ve used one on a cartridge man music Master LE
And I’ve used the cartridge without it too... tbh I’ll be buggered if I could hear what it was doing.. except for increasing the VTA fiddle factor
"lack of passion is fatal"
I'm Johan.
Try to set your TT no a shelf. Best way to stop feedback.
I'm Richard.
Gents. Lots of great info here. Thank you. I agree that it is unlikely to have any effect on the subsonics but having tried absolutely everything else I am clutching at straws. That said, the KAB filter is astonishingly effective and I replaced the bearing housing with a PEEK upgrade which has been helpful too. The KAB is active with a switchable cheap power supply so I’ll upgrade that next. Anyway, having read about the resonator around the www clearly some think it’s terrific, and Len presumably wouldn’t hang his formidable reputation on a suicidal hook. But there is nothing much positive expressed by some pretty learned turntablists on this thread so I will gladly park the idea. Beobloke’s absolute clarity is a cracker and a clincher! Thank you everyone for your input.
The cartridge is fitted to the underside of isolator using double-sided sticky tape, with the upper surface fitted to the arm/headshell using the attached bolts.
https://www.tnt-audio.com/accessories/isolator_e.html
One could easily knock up something very similar if you have a few DIY skills for a lot less than the £100 asked!
I'm Richard.
Thanks Barry but I can also buy an equivalent from SRM for under £20. I think the material choice is probably key. Also it throws the VTA and all sorts and I don’t want the faff. Personally, I have no doubt that Len Gregory will have experimented majorly with materials and combinations which is why it is priced as it is. I’m not up for the R&D myself. If one of the learned turntablists - or a few ‘normal’ people - had raved about it I’d have taken a punt but I’m more than happy to forget it. Thanks for the input though.
