Results 1 to 10 of 16
Thread: dave slagle pre build
    I'm Phil.
    Default dave slagle pre build
    Building a dave slagle pre , using a seiden 2 pole 23 step attenuator , I understand the wiring from the autoformers but its wiring the switch that has me thinking this
    is from his site ,
    Thats all there is to it! Pay close attention to the switch rotation. When the switch is rotated all the way counterclockwise (off) this is where the ground connection goes, then as you rotate the switch clockwise you simply connect the taps in order (-42, -39 etc.). If you reach full volume (the signal in lead) and still have remaining taps on your switch, simply connect them all together or insert a stop to prevent any contacts from being left open. Further questions about hookup can be asked in the forum.
    its the ground connection that has me confused , if you connect the first pin of the switch to earth it then joins with the output which would give you a short , or am i missing something , any clues phil.
    Phil.
    I'm inthescottishmafia.
    Yes, that’s what you want with the volume fully counter clockwise, means there will be zero output, which is what you want.
    Hunter S Thompson
    I'm Richard.
    The input connects to one end of the AVC winding. The ground to the other end, as he says. The output (wiper on a pot) connects to the moving contact on the switch. The input to the power amp will indeed be grounded at full attenuation (just like a pot), but the output from the pre will not, as the signal has to pass though the whole of the winding to get there.
    Does that help? I'd be interested in the results, as I use a TVC on the output of my 01A pre, but considered a Slagle AVC.
    They are very good indeed, I built one a good while ago. Sold it on when I got hold of some Tribute autoformers, not sure they are much better if at all though.
    Hunter S Thompson
    I'm Phil.
    So basically the 42db attenuation would still allow some sound from the speakers , so the first segment OFF position joins ground and output , this
    would be like the 2 wires touching in a pair of interconnects . isnt this a short . phil.
    Phil.
    Yes, but that's fine, won't do any harm.
    Hunter S Thompson
    I'm Phil.
    Hi dick , when i get the soldering sorted ill let you know how it sounds , i think i understand now about grounding the output , cheers for your help phil.
    Phil.
    I'm Phil.
    cheers for your help , phil.
    Phil.
    I'm Richard.
    Quote Originally Posted by oceanobsession View Post
    Ah, no. There are three wires here, and the important one, the output from the pre, is never shorted. Input to power amp is. Whenever I test a power amp for faults, I generally start with the inputs shorted to minimise spurious noise.
    ABD.
    I'm Richard.
    I have a Glasshouse TVC upgraded with Sowter transformers, used as a stand-alone unit or at the output of the 01A DHT pre (input pot turned to max) as the volume control. If I was closer (to practically anywhere, I live in Plymouth!) it would be interesting to compare the two.
    ABD.
