Receive a free V90-LPS Phono Stage, when you purchase the Musical Fidelity M2si Amplifier from Fanthorpes HiFi. Saving you £149!
Musical Fidelity M2Si Amplifier
The M2si integrated amplifier takes Musical Fidelity’s peerless premium sound experience and applies it to a more affordable price point. Boasting trickle-down technology from the legendary Titan flagship model, the sound is well complemented by other high-end touches, such as the solid metal controls.
Delivering 76W per-channel into 8Ω (137W into 4Ω), the Musical Fidelity M2si has the power to drive a wide range of similarly-priced loudspeakers, including the more power-hungry models. But it’s not just a question of power, as the M2si Amplifier features a Class A pre-amp stage with its own independent power supply, coupled with a pair of discrete power amps. The end result of the advanced internal design means the M2si effectively offers the performance benefits of a pre/power configuration but with the convenience of a one-box solution.
Musical Fidelity V90LPS Phono Stage
The V90-LPS has extremely accurate RIAA correction and that extends up to 80 kHz and beyond. That may sound extreme, but there is a good deal of information above 20 kHz that needs correction. If it isn’t corrected, it will show itself as ringing and overshoot.
The V90-LPS’s distortion is very low. Noise ratio is extremely low and all but inaudible.
Overload margin is easily adequate for any current cartridge.
All in all, the V90-LPS accomplishes everything necessary for a phono stage.
There are many phono stages that are far more expensive and make extraordinary claims for their performance. In contrast, the modest V90-LPS just gets on with the job of doing everything you could reasonably expect from a phono stage.
If you want top notch performance, and don’t care about the alleged conferred status of buying a high-priced product that offers no better performance than the V90-LPS, then we are of a like mind.
V90-LPS In Brief
Switchable MM / MC input
Extremely accurate RIAA extending out to at least 60kHz
Very low noise (virtually inaudible)
Very low distortion
Excellent overload margin
Excellent channel separation
Beautiful, considered build quality
Trade In
At Fanthorpes we love to trade in, so if you want to trade in your existing HiFi against new HiFi, contact us and we will let you know what it is worth as a trade in.
Finance Available
We can also offer buy now pay later on orders above £400, allowing you to spread or defer your payments over a year.
