Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Valve amp question
    Default Valve amp question
    I've bought a brand new integrated by Mistral. It has 4xEL34, 2xECC83 and 2xECC82. I noticed that when switching on one of the small valves glows very bright for a fraction of a second initially then goes back to normal. The other three are always normal. I thought this might be a function of the cheap Chinese valve but when I switched to NOS valves (all except the power valves) the new one does the same.
    Does anyone know what the most likely cause is? If it was both of one type I would presume it's just part of the design but as it's only one of them (presumably in one channel) then it doesn't seem right. Should I be worried, at least about valve life if nothing more?
    Thanks in advance for any advice.
    I've found that many valve amps are a bit quirky in this way. I think its about the circuits coming to equilibrium when first switched on. Sometimes a valve will glow a bit momentarily and sometimes there will be an audible hum in the speakers for about a second. I think this is pretty normal and even occurs in some AudioNote kit.
    Apparently there are ways to ameliorate these effects, but it involves additional circuitry that almost always has an inverse effect on sound quality.
    Cheers Chris
    Source
    SW1X USB II
    SW1X DAC III Special
    Audiolab 6000 CDT transport
    Amps
    Speakers
    BK Electronics XLS400FF Sub.
    Cabling
    Headphones
    I'm Shaun.
    My amps have a switch on delay so that the valves only reach full capacity a minute or so after power up. Just a thought.
    I'm inthescottishmafia.
    This is quite normal and is nothing to worry about.
    Hunter S Thompson
    Thanks all I'm less worried than I was, but still a little perturbed that only one of the two ECC83s does it, it makes me wonder if there is some imbalance between the pair in the circuit, although there is no audible channel imbalance.
    Once you've had a listen let us know what its like. I'm after an EL34 valve amp meself.
    I've been listening for a week now it's bloody lovely! I need to decide which one of my EL34 amps to sell as I want to keep them both!!
    My VTL pre does that on one of the ecc82's. None of the others do that and it has no effect on sound or running.
    Thorens TD550, Ortofon 12", Ortofon Jubilee or Koetsu Black; Rothwell MCL SUT, VTL 2.5 pre, XTC POW 1 power; Naim CD5x; KEF Reference 3.2's; Van den Hul interconnects and speaker cables.
    Quote Originally Posted by Slawts View Post
    That's good to know. I wonder if a slight difference in resistance or whatever in one channel means the switch on surge all flows through the path of least resistance.
    The heaters of the EF86s in my Radford STA15 III intially glow brightly on switch-on, then immediately 'die down' to a normal glow. So nothing to worry about!
