Just for reassurance
https://www.theabsolutesound.com/art...5-loudspeaker/
which I'm sure you've already seen.
You lucky man; i had 57s for a while before i got my Klipschorns, in 1980, and still recall how great they sounded.
Chris.
I'm Richard.
I've bought the pair on ebay. When he responds, anyway. I'll be picking them up on Tuesday; the packing and strapping in the back of my MPV will be fun!
I'm Richard.
I took my big Troels speakers to the buyer in Croydon, set them up for him, picked up the 2805s and drove back to Plymouth! My son came down from Manchester and helped me, otherwise I would have been stuck.
i do like the rich, yea olde colours and style of the room. it reminds me of better times.. must be nice place to sit
Give them a little more space to breath behind.
I'm Richard.
One of them is faulty. The dustcover membrane on the front of one is torn, and its top mounting strip is loose. I played some music with a double bass and it started farting! Only double bass, not drums, or even some electronic dance music, just double bass. Of course I didn't play any of that when I listened to them at the vendor's house, so it didn't show up. Now there will be the fun of trying to sort it, probably myself, as it is a long way to Quad or OTA.
I have found out how to remove the covers, at least, but the screws have been butchered, and on the back of one, four out of five are missing, plus there are three types of screw used. The vendor claimed these had recently been serviced by OTA!
Hi Richard,
I'm sorry to hear about your woes. I have recently had a similar experience with my purchase of some 63's. (Although not the sellers fault at all in my case I suspect). Listened to them at the sellers house and they were fine. He was a lovely guy who could not have been more courteous and even if the problem was already with the speakers he did not know about it. Got them home, farting from a bass panel on low bass notes.
As mentioned, my situation differs from yours in that it sounds like yours had issues before you bought them judging from the missing screws etc (I don't think OTA would leave them like that).
Is it the actual panel that is torn or just the dust cover/membrane working loose? I believe it is the latter in mine and is apparently not the most difficult fix in the world. (This info from my seller who has actually very kindly offered to help me sort them when we have the time). It basically involves removing the socks and gently heating the dust cover until it re-seats itself (or something similar to that explanation).
The diagnosis of it being the dust membrane rather than the panel/diaphragm is only from what I've read, it sounds like an audible buzz/fart from a specific area near where the bass meets the treble panel.
Even though I've owned quite a few I've never actually been inside a pair of Quads, I might be biting the bullet soon though.
As I've mentioned before though, unfortunately this is one major caveat of ownership as they are delicate. However when properly setup, working and looked after they can run problem free for years even decades.
They are worth getting right.
Of course there is always OTA and Quad repair route to go but as I know for-well this is galling having just spent money for what you assumed were a fully working serviced pair.
Best of luck.
Chris
I thought you said OTA had confirmed they had serviced the 2805s?
