AC POWER
AMPS
SPEAKERS
Wharfedale Evo 4.4
DAC
TURNTABLE
PHONOSTAGE
DIGITAL
MUSIC PLAYBACK
Ipad Roon Remote.
SPEAKER CABLES
INTERCONNECTS
Who says I'm not a Sith?
I don't get your thing about bit depth. All bit depth does is determine the maximum dynamic range possible. 16 bits gives more dynamic range than you need for 99.99% of recordings and even then it is probably higher than the amplifier is capable of anyway - what is the weakest link with regard to dynamic range in any system? It isn't going to be the digital source even if it is a supermarket brand DVD player.
All very well to talk about the effects of aliasing, bit depth, pre and post ringing, jitter etc, but can you hear them when music is playing? And the answer is no. If these things were audible vinyl would sound terrible since its sins are of far worse magnitude in these respects.
Archimago did an interesting experiment to demonstrate that even with high jitter and drift values you can't hear the differences. He created versions of a track that had jitter and drift values far in excess of even poorly designed DACs.
This is his write up and the relevant tracks can be obtained here.
Anyway I certainly can't hear any differences - even after several plays. I was keen to hear differences so as to confirm my positive bias I have towards my set up. It is not to be.
All depends if you suffer from Al Gore isms
Definitely bit depth matters. However if you upsampled a 16 bit track to 352Khz (or whatever frequency) whilst staying with 16 bit wordlength the resultant track will sound worse due to rounding. Any digital manipulation needs to be done at a high enough bit depth (typically DSP these days do things at 64 bit floating) and then dithered down to the end result (16, 24 etc). Your 24 bit 44.1khz track will sound better then the 16 bit upsampled track.
Or did I misunderstand your post?
Of course the upsampling engine you used may be at fault.
been using dsd in main system as audirvana does it and pc over there has enough memory etc so there is no problems
I think your comments are theoretically correct - but some people might find that practically they're not - for them at least. I can't actually comment sufficiently well on audio, but I have done work with video and image files. Much of the theory is the same, but sometimes it is definitely possible to get a much better visual effect with some digital processing, and perhaps also upsampling. Compared with the original images the modified ones must have been less good, because of the processing, but most people would prefer the edited ones.
There are limits to what can be achieved, however, sometimes the improvements are only slight if there's insufficient detail in the originals.
Dave
That's the key point. When the vinyl record was developed I am sure that few people could imagine how much information could be recorded in the grooves. At the time, the technology to retrieve the Nth degree of detail from a groove was not fully developed. Over the years, there has been a progressive improvement in technology and engineering so that albums recorded and pressed 50 years ago (or longer) can sound fantastic. Yes, there were very good reproduction systems around by the 60's, but they were the exception rather than the norm. I believe the same applies to digital. When the CD was launched I contend that the same was true: that there was an imbalance in the audio chain and that encoding analogue to digital was more successful than the reverse process. I could barely listen to cd when it was first launched. I was particularly sensitive to the high frequency playback and what I now perceive to be "time smearing". Again, there were a few decent cd players around, but most were way out of my budget. Over time, these problems seem to have been addressed and I am now happy to have all but switched over to digital. However, it has taken a long time to make good quality digital reproduction truly affordable and for me the biggest improvement has come with the better processing of digital to analogue through upsampling.
AC POWER
AMPS
SPEAKERS
Wharfedale Evo 4.4
DAC
TURNTABLE
PHONOSTAGE
DIGITAL
MUSIC PLAYBACK
Ipad Roon Remote.
SPEAKER CABLES
INTERCONNECTS
