Thorens TD550, Ortofon 12", Ortofon Jubilee or Koetsu Black; Rothwell MCL SUT, VTL 2.5 pre, XTC POW 1 power; Naim CD5x; KEF Reference 3.2's; Van den Hul interconnects and speaker cables.
I find that feeling wears off after about 72 hours replaced with 'how can I improve things?'
By the way here is a snapshot of the old goldenjacks website. Interesting read.
I would be tempted to use attenuators to figure out the exact amount of attenuation I needed, and then have someone technical solder in a voltage divider (which is what the attenuators have, inside the plug), using really high quality resistors, hard wired to the input sockets of the power amp. You can always have them removed if you ever switch to a preamp with less (or no) gain.
It's an odd thing, and technically shouldn't be but I've found external ones do kill dynamics a bit.
I free with Tom find what you need and get it fitted into circuit.
I'm gordan.
Gordan.
Speakers: Oris Swing MkII
Amps: Thomas Mayer 300b/ Hiraga La Maison de L'Audiophile 20
Preamp: Silver AVC by eng. Ferenc Lazar
Phono Preamp: Shishido LCR by Solaja Audio
Decks: Garrard 301 Martin Bastin reworked/plinthed with Fidelity Research FR64fx
Garrard 401 in eng Ferenc Lazar solid wenge plinth with SME 3012/2
Cartridges: SPU Spirit/ Koetsu Black revisited by eng. Salai/ Miyajima Shilabe
Step Up Transformers: Tango MCT 999/ Ortofon T-5000/ Lumiere SUT
Digital: Shigaclone by eng. Ferenc Lazar with Lampizator Amber II
Wires: of sufficient length
I thought i would just revive this as it is now a month since I had the Rothwell attenuators in.
I have now forgotten about them but my albums and stereo are much happier.
I have a quiet soundfloor and the detail is much much better.
The only downside is I have put the Koetsu back in preference to the Ortofon Jubilee and it sounds spectacular.
I am trying not to develop a love of high end cartridges and especially Koetsus (that way penury) but it is proving difficult.
Be careful what you wish for.
