Results 1 to 10 of 11
Thread: Standby State of Your RPI Player
    I'm Paul.
    Default Standby State of Your RPI Player
    What do people do when not listening through your rpi?
    Do you completely shut it down as I do and remove the power source or do you just keep it powered on 24/7?
    I'm guessing this is going to depend largely on what power source you are using but just wondered what others do?
    Sent from my CLT-L09 using Tapatalk
    Current system:
    RPi + Allo Digione
    Beresford Caiman Seg & Dorado powered by 15v Linear PSU
    Transcendent Sound Mini Beast OTL
    Amptastic Mini-1
    Klipsch KG4.5 Speakers with Titanium Diagphrams and Sonicap Cap upgrade
    110aH Leisure Battery powers the Mini-1 & Digione
    I'm Andy.
    All of mine are on 24/7.
    Main system:
    Analogue.
    Network Player.
    Digital.
    Philips DCC 730 player
    Marantz CD50SE
    Amp.
    Audiolab 8000A
    Speakers.
    Reiver Jenna floor standers
    HeadPhones.
    Bigman80 Guest
    Quote Originally Posted by gninnam View Post
    If the system is on (usually) then the Pi is always on too.
    I'm Tony.
    I switch mine on and off when using it (Katana/Shanti dual power supply).
    Haven’t had any issues and the valve amp warming up is the actual bottle-neck to listening.
    I'm Peter.
    RPI / KATANA / ISOLATOR...On 24/7 (2 x IFI Linear power supplies). No issues whatsoever.
    On 24/7 as it uses virtually nothing
    Used to be but it's in an Ali digione case now so usually switch it off. I also have an on line switch so I don't have to unplug etc.
    The times it's been left on for several days it's been OK although case gets quite warm
    I'm Barry.
    Turn mine off with a switch on the power supply after shutting the pi down from within moode.
    I'm Greg.
    I switch mine off when at work and at night. Sat and Sun all day on.
    Mine is powered from a dual linear PS. No efficient SMPS.
    I'm Alastair.
    I use battery power, so switch it off when not in use, like the rest of my gear.
    Sent from my SM-G950F using Tapatalk
    Cheers
    Alastair
    RPI4/PI2AES running PiCorePlayer/LMS-> AQ Carbon AES -> Topping D90 DAC-> Khozomo Passive Pre-Amp -> 4x Temple Audio Monoblocks powered by 2xLiFePO batteries->Van Damme Black Bi-Wired to B&W 804 Nautilus and Sommer Carbokab 225 Interconnects
