Valve rolling is a slippery slope. :-)
Hunter S Thompson
Another Sovtek 12AX7LPS recommendation here as a cheapish new valve.
Keep an eye out for Ei ECC83 /12AX7s too. They have not been made for a few years now, but used Telefunken smooth plate tooling. They were often branded as Marshall, Edicron, RCA as well as Ei. So can still be found at reasonable prices if you know what to look for. They have a 2A1 etched code near the base...
Thread moved from Analogue Art to Blank Canvas, as it's not really about playing records!
...and subsequently moved to where it *actually* belongs, as the thread title is 'Tube Rolling'!
Description of the Artist's Palette (edited):
Seems like even some mods don't READ things properly....Info on tubes and headphones (inc. headphone amps and systems) should also be discussed here.
If the main theme of the discussion had been about music, the place for the thread would've been in Musical Compositions. If the main theme had been cartridges, then it would've gone into Analogue Art (where cartridges, and everything relating to turntables, or other analogue source components, is discussed), and if the main theme is actually about tubes, then, as outlined, it should've been put here.
The main theme of the discussion dictates where threads should go. It's all about the main theme
Blank Canvas is for all hi-fi discussions out with of those covered by the dedicated sections underneath, or anything else that doesn't appear to have an obvious 'home'.
This stuff ain't rocket science, folks!
Try NOS Mazda ecc83's. They tend to be cheaper than old Mullards but sound much the same. I have 2 which I tried in my phono stage and they sound equally as good as my old shield Mullards.
If you have the valve that came with the Project even a new JJ or Tungsol ecc83 will sound better.
You will end up buying a selection like the rest of us anyway so just dip a toe depending on how much you want to spend.
Thorens TD550, Ortofon 12", Ortofon Jubilee or Koetsu Black; Rothwell MCL SUT, VTL 2.5 pre, XTC POW 1 power; Naim CD5x; KEF Reference 3.2's; Van den Hul interconnects and speaker cables.
