Results 1 to 10 of 18
Thread: Tube Rolling.
    Default Tube Rolling.
    Hi guys,
    Since my last post about my old Ortofon VMS20E, I’ve replace the stylus with an Ortofon VMS3E and she’s singing again.
    My next plan is to change the valves (ECC83 / 12AX7) in my Project Tube Box.
    Anybody done this and what would you recommend?
    I'm inthescottishmafia.
    Depends how much you want to spend. :-)
    Hunter S Thompson
    I'm AnDreW.
    Telefunken ecc83s or Mullard cv4004 both extremely expensive and thought to be the best by many. I use both and are dependent upon equipment. Good luck with this one.
    CD Teac VRDS25X(Audiotuned) DAC Caiman SEG+15V PSU+Dorado DECK 1210 Mat Crystal Audio Mods MN Base/Bearing/Platter+Ebony armboard Feet Isonoe/Ebony PSU Paul Hynes SR7EHD-27XL/DCSXL Ag DC lead/3 Stage Regs/Recap PCB+No Pitch/Strobe/Light ARM SME V(Kondo Ag Rewire&Tags) MC Cadenza Black FGS CABLES Arm Yannis SPD-4 IC Yannis 222 Litz+Ag bullets Power WAR PRE ATC SCA2 SPEAKERS ATC 50ASL STANDS Atacama PHONO Sugden Masterclass PA4 SUT Ortofon ST80SE POWER PSAudio P10
    PRE
    Croft Epoch(Modified) AMP Sondex S100 (Modified) SPEAKERS Tannoy 15"MG+RFC Warwick cabs+ Reference XO DECKS Garrard301/401 (Bastin) Mat Teunto Bearings 301/401(Bastin) Plinth Moldovan/Bastin Arms 3009/3012(Ikeda Ag wired) SME V 12 PSU Eagle+Tachometer MC Ag Meister v2 / Royall N SPU's CABLES Arm Yannis 420.5 Litz+ Speaker 10mm Cu + WBT-0681 Ag IC Oyaide FTVS-510 AgWBT 0110Ag Phonostage Paradise(4 Box Modded) / EAR 834 Clone (modded)
    REAL SOUND
    PRE Radford SC25 (Mullard ECC83/82) POWER RADFORD STA25 Renaissance (Electroharmonix EL34) SPEAKERS Celestion Ditton 15 (Duelund Rewired/Jantzen Recapped) CABLES Speaker - Duelund AWG 12IC - Belden 8402+Switchcraft RCA
    For a new budget one I rather liked the Sovtek 12AX7LPS I had in a pre a while ago.
    I'm Oliver.
    Can only recommend Telefunken as they were the best (IMO) of any valve I tried, and that was MANY!
    I'm Peter.
    Agreed. PM sent.
    I have Mullards and Tele’s amongst others. Best I’ve heard are Tungsram foil getter with welded plates. A good pair of NOS of any of the well known quality makes should be good though.
    Hunter S Thompson
    I'm Justin.
    Tesla ECC803S factory code 32 yellow print gold pin.
    As good as the Telefunken ECC803S. I have owned both at the same time.Even made with the same tooling equipment.
    Mid-80s Mullard CV4004 white box mil spec.
    I'm Justin.
    ECC803S is just a special quality ECC83.
    Thanks guys, much to ponder upon
