Results 1 to 9 of 9
Thread: Wanted: Linn geometry tonearm for use on an LP12
    I'm Ant.
    Default Wanted: Linn geometry tonearm for use on an LP12
    As above, must be in good order all round please.
    Budget around £500, may stretch a little for something really nice!
    Many thanks
    RO
    A Jelco arm is a drop in replacement, I understand. You could also look for a Roksan Nima
    Lumley Heliosphere Audiomods 5
    Hovland HP200 MC
    Hovland Radia
    Ming Da 805 monos
    Magnum Dynalab Etude, RWA Cassabria + LCD 3
    Wilson Benesch Actors
    I'm Andy.
    Sorry I completely misread that post LOL
    Analogue
    401 / PU7 / AT33ev
    Digital
    Innuos Zen Mini Mk 3
    Topping D50s
    Caiman Seg & Dorado
    Cambridge CXC
    Amps
    Tron Seven Linestage
    Speakers
    Tannoy GRF Memory.
    Tannoy ST100.
    As far as I understood it a Jelco SP distance is a few mm more than Linn geometry. Whether that makes any difference is another matter but just thought I'd mention it.....
    I'm mark.
    Quote Originally Posted by ovlov854 View Post
    Nima's Rega geometry... Jelco's more like 215mm, Linn's 211mm.
    Ittok's the obvious one, but others that'll fit are Zeta and the old Helius Scorpio (so good AN cloned it) Aurius. Alphason's a drop in too.
    Synrinx is the correct geometry but needs a different sized hole.
    I'm Rob.
    Is the arm intended for an LP12? If so, changing the armboard is a fairly simple thing to do - if you are changing the arm, all the hard work (alignment etc) will need to be done any way. Changing the armboard will make a lot more arms viable. SME and Rega mount being the obvious choices, but others are also possible (e.g. I use an AudioTechnica AT-1010 in my LP12).
    Rob.
    Powered by crossed fingers and clenched buttocks
    I'm Ant.
    Yes going onto an LP12 and the sub-chassis I have fitted requires a Linn geometry tonearm
    Many thanks
    I'm Ant.
    Now sorted, many thanks
    What did you get?
    Hovland HP200 MC
    Hovland Radia
    Ming Da 805 monos
