Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: usb v coax
    I'm Edward.
    Did you see this page?
    https://support.auralic.com/hc/en-us...-output-device
    Also perhaps try connecting the DAC to another USB output. Such as from a PC for example. This should give you an idea where the blockage is to allow further analysis.
    I'm Tony.
    Hi Robin
    USB is only used as it has billions of connection possibilities with PC's/Lab tops and other items in the IOT range of products etc.
    USB will allow higher sample rates due to DoP and DSD many companies have attempted to improve USB audio data transmission over the years with varying success. Unless your dac and transport can utilize duel digital outputs of either AES or RCA ala' Esoteric or DCS.
    Personally I will not use USB straight, I have always found AES67 to be the most consistence performer even over I2S via HDMI can even demonstrate the jitter patterns through the cables to support this. However as always YMMV
    It is all about implementation and adopting the correct care in the design process imho
    Coherent Systems
    Real high end sound with musicality not hifi
    I'm Edward.
    Quote Originally Posted by Mr. C View Post
    Hi Robin
    Hi Tony
    Interesting.
    Both my dacs have Aes/ebu inputs.
    How do I get a signal from a pc (half height etc) to the Dac? The only outputs the pc has are USB and spdif. (need to check the motherboard manual mind you).
    Is there a bridge of some sort I could consider?
    Meantime hope all is well.
    Ed
    I'm Tony.
    Hello Edward
    I am fine thank you just somewhat busy as usual.
    PC use can use a pro audio pcie card with a 90 degree adapter is one option.
    These are pretty acceptable
    RME Option
    Though you may struggle with the height.
    The Linx version will require an adapter cable to give you the AES female sockets
    Linx PCIE
    This purely depends on how far you wish to go.
    Another option is the Mutec MC3+USB it delivers USB to a very decent standard plus with flexibility and a word clock generator plus format conversion.
    Mutec MC3+USB
    Coherent Systems
    I'm Edward.
    Hello Edward
    RME Option
    Linx PCIE
    Mutec MC3+USB
    Cheers Tony
    Much appreciated. The Mutec/USB combo looks most interesting.
    The RME and Linx options would, for me, require a reconfiguration of the PC I use as an end point but probabky gives max flexibility.
    Meantime I hope that Robin the OP finds out what the issue is on his problem and does not mind this minor thread drift.
    I'm Robin.
    Tony is a good egg - always willing to help! Thread derails? Who cares!
    Robin. mit ARC CD9, ARC ref 5 / darTZeel power + magico v2. Clearaudio Innovation wood / Phantom ll / Lyra Atlas / Aurorasound Vida,
    Stax 009S cans.KGGG headamp. all connected with wires. Auralic Aries - Aqua La Scala. Manley Absolute. Focal Stellias. HD800S Hyland headphones - Venus
