From a streamer to a dac is there likely to be a loss of quality using the coax rather than usb connections. Asking because the two units don’t want to communicate via usb whereas the coax presents no issues.
I'm Robin.
Robin. mit ARC CD9, ARC ref 5 / darTZeel power + magico v2. Clearaudio Innovation wood / Phantom ll / Lyra Atlas / Aurorasound Vida,
Stax 009S cans.KGGG headamp. all connected with wires. Auralic Aries - Aqua La Scala. Manley Absolute. Focal Stellias. HD800S Hyland headphones - Venus
I'm Robin.
yup best telling of what the line is. ie what is connected to what. might be a driver issue
I'd try connecting both and rebooting both. see if the see each other. otherwise also check cable for issues. contact benchmark and ask if their dac is comparible with the aries
quick restart if the mini but may well be all is to .. Press and hold 'EXIT' button on the remote control for 7 seconds to force the system to reboot, or Briefly press the 'RESET' button under the device using a paper clip.
I'm Robin.
Thanks for that. Tried every which way already hence my use of coax. Just wondered if the coax link is inferior to usb because if not then would save a lot of hassle.
I'm Mark.
Having a quick look at the pages for both the aires and the dac it should connect ok if the dac is set to USB Audio Mode 2, details are here about how to check / set mode 2 https://benchmarkmedia.com/pages/dac-drivers
it maybe worth checking as it says the Dac ships set to mode 1.1 (usb 1.1) woth a look.
If the USB takes the power, then you may find the coax is better.
