Slightly later iteration as per this.
https://www.lpgear.com/product/GA1.html
Bought in 2008 but low use , maybe 200 hours before I upgraded. lmk if interested £35 delivered ? Can send you a photo if you want.
Sent from my SM-G950F using Tapatalk
At the cutting edge of Numptyness!
No worries, its mm only.
Pawnshop integrated is your best bet IMHO
bump
why is nothing ever simple?
I'm Mark.
Hi, I’ve got an Angle Audio. It’s mm/mc though I only ever used the mm. It has the ‘virtual battery’ but I modded it slightly so that it works off a wall-wart now with no discernible loss of SQ and of course that ensures it’s never out of power now. Easily changed back to battery if desired.
Message me if you have any interest.
Would this Pro-Ject phono box be of interest?
MM and MC (selectable via internal dip switches). Includes psu and I'm 99% certain I have the original packing.
Some surface scratches.
£50 collected?
Sorted.
Thanks to all.
