Results 21 to 30 of 42
Thread: Unstable Tracking Force Conundrum- a ghost in the machine ?
  1. #21
    I'm Stephen.
    Quote Originally Posted by scotty38 View Post
    Agreed but I had assumed you couldn't tell (no markings??) based on considering other options. Having said that how does a heavier weight fix the issue that the current one is moving as I don't see the correlation?
    Because it will be a lot nearer the pivot and fully inserted in the arm tube.
    Always a little further
  2. #22
    I'm Adrian.
    Quote Originally Posted by worrasf View Post
    Adrian
    While the counterweight is at the very rear of the arm it is clear of the dust cover in its tracking arc. Also, I don't close the lid as the Brueil record weight is too tall.
    I do think though that the issue is likely related the counterweight being so far away from the arm pivot. Unfortunately, I am not aware of a heavier counterweight for this arm.
    Even though we have not yet reached a definitive reason for the problem I am sensing that the received expert opinion is that it is unlikely to be due to the cartridge suspension which supports Terence's view.
    Steve
    With my Timestep headshell and Benz Micro LP-S my tracking weight is very near the end of its adjustment, which is to be expected based on the specifications I think it is within 2gm of the limit.
    A simple think to try out would be to get a small amount of blu-tack say 3-4gm and out it onto the counter-weight, them balance out the arm, zero the gauge and the then set it for your tracking weight and then see it it remains stable.
    Before you do the above see if you can easily slide the counter-weight back, you should not be able to do so if it engaged on the thread, so if it isn't then you have exceeded what it can do with the existing counter-weight.
  3. #23
    I'm Stephen.
    Good suggestion that.
  4. #24
    Ah ok, I'd not realised it was set up like that, fair enough makes sense.
  5. #25
    if its partially off the stem that will cause issues with it moving.. meantime try a little plumbers tape. might just give it enough grip
    I'm Stephen.
    Another good suggestion
  7. #27
    Interesting conundrum, and I agree that the cart. cannot be responsible except inasmuch as it may generate a lot more energy that your others.
    I had the same thing happen on my 12" PU7, when the VTF would inexplicable change (can't remember if it was lighter or heavier though). The P U7's counterweight is secured by grub-screws, and although feeling tight, they weren't, causing drift over a few records.
    Don't know your Jelco, but think it may be a grooved/twist affair with no locking, but the principle remains and I think Adrian, Martin et al are on the right track in suggesting masking tape or whatever to secure it. Sounds improbable for such a counterweight to be able to creep, but this and the cart. weight/higher VTF/energy effect on the counterweight is at least a feasible possibility.
  8. #28
    I'm Stephen.
    Quote Originally Posted by Mike Reed View Post
    Thanks - Yes I agree it must be the counterweight slipping. Hugo Cass informed me earlier there is no heavy counterweight available and I’ve not seen anything from the likes of Isokinetic. I’ll try the “tape” method at some stage and if successful maybe try and commission a custom weight.
    Thanks to all the ghost busters
    Steve
  9. #29
    I'm Adrian.
    Steve
    See if it is magnetic and if so just add a small magnet or two to the rear, could save a lot of cost.
  10. #30
    Might be obvious but I assume the sleeve is fully on the arm and that the weight is towards the rear of the sleeve. Ie you don't have the weight forward and the sleeve hanging off the back....
