Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 42
Thread: Unstable Tracking Force Conundrum- a ghost in the machine ?
    I'm Stephen.
    What TFGuage are you using , I had all sorts of problems with this type
    https://www.ebay.co.uk/itm/0-5g-LED-...18d8413f0ae269
    It is similar and I'm aware of the issues with cheap strain gauge balances which is why I double checked with the old fashioned but very reliable Shure SFG 2 and both read very very similar so am happy it's not the balance. Also, there is no problem with the other cartridge/headshell combos
    Always a little further
    I'm Adrian.
    Steve
    Just a thought, what Turntable is the arm on, I have Jelco TK850M and it is a very stable arm and tracks very well. One thing I am wondering is even though yours if 9" with the Denon fitted how far back down the arm is the balance weight to get the arm balanced and then set the tracking weight? If it is the heaviest of the 3 cartridges you have, if your TT has a cover and you put it down when playing a record or after (having just set it up properly) is it possible for the cover to catch on the weight and then throw it out?
    The reason I ask is I cannot put my TT cover down when playing a record as th e10" arm over hangs at the rear and at about 3/4 across an LP the weight will come into contact with the cover.
    This might explain the issue.
    Cheers
    Adrian
    I'm Allen.
    Steve
    Cheers
    Adrian
    Oooo , I like that theory , Top thinking Sir
    I'm Stephen.
    Steve
    Cheers
    Adrian
    Adrian
    While the counterweight is at the very rear of the arm it is clear of the dust cover in its tracking arc. Also, I don't close the lid as the Brueil record weight is too tall.
    I do think though that the issue is likely related the counterweight being so far away from the arm pivot. Unfortunately, I am not aware of a heavier counterweight for this arm.
    Even though we have not yet reached a definitive reason for the problem I am sensing that the received expert opinion is that it is unlikely to be due to the cartridge suspension which supports Terence's view.
    Steve
    I'm Robert.
    Steve
    Cheers
    Adrian
    Yeah,
    Have knocked mine out like this before - drives you nuts ! hence I ended up having a bespoke cover made in the end, at the time.
    My System:
    CDP - Pioneer PD-91
    Don't have an answer as such but surely it's the actual tonearm weight moving because if it wasn't, after a number of adjustments it'd be off the back of the arm.....
    I'm Stephen.
    Quote Originally Posted by scotty38 View Post
    Occam's razor answer - thank you
    I suspect you are correct.
    I need to find a heavier counterweight
    Steve
    Can you not set it up and mark the weight and arm in some manner then you'll see what is happening?
    I'm Stephen.
    I suppose the fact that I have to wind the counterweight back is an indication that your suggestion is correct.
    I am going to see if anyone can make me a heavier counterweight.
    Agreed but I had assumed you couldn't tell (no markings??) based on considering other options. Having said that how does a heavier weight fix the issue that the current one is moving as I don't see the correlation?
