Results 1 to 8 of 8
Thread: Quad 909
    I'm Allen.
    Default Quad 909
    Hi People, My 909 should be home from quad tomorrow after a good coat of looking at ( Birthday )
    It has had the caps replaced 4 transistors and a new RCA board fitted and run up for testing , tested all good
    What do you run it with? Pre amp wise.
    I'm Allen.
    This unit is new to me purchased from a PF member as damaged , He managed to snap off a RCA connector
    using over tight RCA plugs , I will try it with my Croft 25R and my Albarry 1108 both have volume controls
    I'm Ian.
    May be of interest, GC advised me to stick a 12bh7a in the line stage of the 25r to reduce impedence when driving the 909. Got one I can let you try if you want but won't be able to post till Monday as I'm away. Anyhoo, worth a mention ;-). Lovely amp the 909.
    I'm Allen.
    Quote Originally Posted by IHP View Post
    Thanks for the recomendation and offer of a try out however I looked on ebay and found a new valve for £13.50 so ordered that , What valve is the line stage one
    I'm Ian.
    Pretty sure it's 3rd from the left but worth someone confirming.
    I'm Don.
    Default Albarry vs. Quad 909
    Audio Al, I know it's an old thread, but did you ever manage to compare the M1108's to the 909?
    Love to know which one came up tops!
    I'm sorted.
    Quote Originally Posted by donmarrese View Post
    Doubt you'll get an answer Don, Al doesn't seem to post these days
