Results 1 to 10 of 14
Thread: Attenuator
    I'm Gary.
    Default Attenuator
    Hi guys,
    I want to make some 10dB attenuators, I'm told I need 1/4w metal film resistors in 6.9k and 4.7k.
    Are there metal film resistors and metal film resistors i.e. Is there a quality or sound issue, if so watts (sorry) best to use.
    Where's best to get them (long live Maplin), or will somebody throw me some.
    I know it's not a complete scenario, but let's just assume I'm right in these values.
    Gary
    Bigman80 Guest
    Just get accurate values and make sure the match per channel. Simples
    I'll have a look at what I've got.
    Hi Gary
    Resistor values easily available are 6k8 and 4k7 , but if you need a 6k9 you could use formula R1xR2 / R1+ R2 to
    arrive at 6k9 with two parallels - 6k8 is probably close enough for the purpose.
    For any attenuator there are known Pad types the L pad being very common, comprised of a series and shunt resistor
    for each channel.
    Metal film is good for the purpose., but would be remiss of me not to mention a LDR being much better.... which is variable
    What do you want the attenuator for? What are the source and load impedances? 0.25W rated resistors will be fine.
    I'm Gary.
    Sorry, I knew someone would ask but I don't have that info. not ideal I know but let's assume as I said above that these values are true, it's just a test.
    Gary
    Gary
    Where will the attenuator be used - between which two items will it be placed? For example between a CD player and a preamp?
    I'm Gary.
    Yes source and preamp
    What is the source: pick up or CDP?
    I'm Gary.
    CD
    Well assuming the CD player has a low source impedance (most likely to be < 100R), and the line-level input of your preamp presents a typical load impedance of 10k, then with a 6k8 series resistor and 4k7 shunt resistor your L-pad attenuator will offer an attenuation of 9.9dB, so the values suggested are quite correct.
