Results 1 to 10 of 13
Thread: Quad 306 and 909 for ESL 63
    I'm Howard.
    Default Quad 306 and 909 for ESL 63
    I’m using a 306 to drive a Quad ESL 63 - there are passive subs driven by another amp. I don’t use a preamp at the moment, I control volume digitally.
    I’m tempted, just out of curiosity, to try a 909. There’s one for sale on eBay which I can return if I don’t like it.
    Is it a waste of time? How will it change things?
    Are there any pitfalls to look for when buying the 909? Are all 909s the same? Does recent servicing make a difference to how they sound?
    If I were in the market for a Quad 909, I would look for one that was made in Huntingdon before the company, as part of the IAG group, was bought up by the Chinese, and manufacture moved to China. There have been consistent reports that local Chinese sourced components are now used, especially capacitors, and that these are sonically inferior.
    This situation may well have improved, so I wouldn't dismiss a 909 out of hand - especially as you can return the eBay item if you don't like it.
    I'm Howard.
    And would that be one that says Huntingdon on the back, like this? (Sorry, I can't make this image smaller!)
    Well the serial number looks low enough (ignore the initial 909), for it to have been made in Huntingdon.
    I'm Howard.
    Ah!
    An issue with the 909 amplifier is heatsink compound was not used between the large internal aluminium bracket and
    the outer heatsink fins. If buying one you need to spend an hour or so, to do this.
    I would in preference purchase another 306, and use one amplifier channel per speaker which is what I do.
    Note you cannot combine the 306 channels to make a mono block, rather one channel per speaker from each 306
    is quite an improvement. You could though at some later stage purchase another pair of 63's and run them stacked,
    with each 306 amp.
    In my system I thought the 909 much better, I think my one was made in China, but it did go back to Quad for a service in 2017. To me the 909 is quite a big step up, the presentation is slightly more laid back, but the gains in detail are worth it. I can't comment on these amps with Quad speakers though, others here will likely have experience of that.
    I'm Howard.
    Quote Originally Posted by Light Dependant Resistor View Post
    Can someone explain to me how doing this can make an improvement? As far as I can see it shouldn’t make any difference at all, but I’m probably missing something obvious!
    It provides better audio as the power supply is then providing to one channel vs two channels
    The 306 does feature separate transformer windings and rectifiers, which you would think was enough separation
    but having tried one amp for two speakers vs an amplifier each for each speaker many times- it speaks for itself.
    There may be other more intricate explanations, in Quads use of a virtual earth for each channel, perhaps the channel running
    is a better circuit slightly where one channel of one amp is running and the other is idle.
    To my ears there is no doubt of its superiority
    I'm Howard.
    Well it's easy to do so I'm very tempted to try, if I don't feel the same as you, I will have lost very little, if I do feel the same as you I will have gained a lot!
    Have you really stacked ESL63?
