Results 1 to 2 of 2
Thread: For Sale : Tisbury Audio Passive Preamplifier
    I'm malcolm.
    Default For Sale : Tisbury Audio Passive Preamplifier
    For Sale : Tisbury Audio Passive Preamplifier, excellent condition and full working order.
    A simple line controller with audiophile acclaimed sound quality. Use it to control volume, switch between multiple sources, connect multiple amps, control active speakers or add outputs for a subwoofer, headphone amp or just about any line-level device.
    SMD Stepped Attenuator
    Key to the excellent sound quality is the stepped attenuator, which utilises an array of thin film SMD resistors to provide precise, stepped volume control and excellent channel balance at all levels.
    New Look, More Inputs and Outputs
    Our second generation preamp now has 3 inputs, 2 configurable outputs and a laser engraved walnut + aluminium enclosure. The chassis is longer, more substantial and remains stable with heavy cables.
    Selectable Fixed Attenuation
    A new feature is the selectable attenuation, which allows you to reduce the signal by a fixed -10 dB or -20 dB. If your system has too much gain and you can't turn the volume dial past 12 o'clock without hearing damage, this setting will help.
    Configurable Outputs
    Output 1 is the primary output and its level is set by the volume control. Output 2 can be configured (by switches on the base) as either an additional primary output, or as a 'tape loop', to bypass the volume control and loop out to another device.
    Handmade in England
    Price £90.00 including postage to UK destinations payable by Paypal gift. SOLD
    Audiophile Tosher
    I'm malcolm.
    Sold
    Audiophile Tosher
