Results 1 to 10 of 17
Thread: Resistor type
    I'm William.
    Default Resistor type
    Hi Guys
    I’m using a SUT and I need to put resistors on the primary side. I’ve used an online calculator and it comes out at 21ohms. So two things really
    1) Do I go for 20 or 22ohms - I would be trying to use a 1% tolerance to minimise the differences between channels
    2) What type of resistor, carbon, metal film etc should I be using. I would like to say that money is no object but of course that’s not true so a compromise will be required.
    Many thanks
    I'm Greg.
    Default Resistors
    Reincarnation...........no not again
    I'm inthescottishmafia.
    Hunter S Thompson
    I'm Hugo.
    I'd recommend Takman carbon resistors - https://www.hificollective.co.uk/cat...resistors.html . More musical, less 'HiFi' than the naked Z-Foils and somewhat cheaper to boot!
    Yep Takman are good also.
    Hunter S Thompson
    Bigman80 Guest
    Audio Note Tantalum, if they have the value.
    I'm Adam.
    Is that really £11 each?!
    And?
    Nobody baulks at paying lots for foo caps.
    You can probably get them a bit cheaper elsewhere, but Hifi Collective service is first class, and you can be confident you aren’t getting fakes.
    Hunter S Thompson
    But foo caps are rolled on the thighs of naked virgins in the dew drops of a golden dawn! Resistors is just resistors innit.
    Personally I also like metal foil and metal film, low noise, tight spec, predictable performance. But then I haven't knowingly heard the resistor magic of carbon comps.
    I do. But I'm a cheapskate.
