Hi,
I am trying to display the images from imgur but it is not displaying correctly. Can someone please advise syntax for displaying the following?
[IMG]https://imgur.com/VHQowyw[IMG]
I'm Graham.
Hi,
IMG and /IMG both in [ ] brackets around the bb code.
On a browser use the little box with a tree in it. It will add the needful by itself. One per picture is needed
I'm Graham.
hi grant, thanks, could you please show the syntax for a full post so I can copy and change. I cant get this to work
[IMG] https://i.imgur.com/VHQowyw_d.jpg?ma...idelity=medium[\IMG]
You need to use the share code. Not sure if you get a choice with imagur but if you do then it's the bbcode. That dash might be the other way. Lol
In the box for replies click on the tree. It will produce a box to paste in the imagur code.
That saves you typing it out
so
i was on my phone so unable to test..
I'm Deleted.
I would add that the code after the image is [/img] and not [\img] (which is why Grant's does not work above*) - the img can be upper or lower case, it makes no difference.
* Well, it didn't work when I wrote this - now fixed.
Account Deleted
I'm Deleted.
An easy mistake to make, as is leaving out the slash altogether.
Account Deleted
i always need to slash
I'm Graham.
thanks for help guys! images now loaded
