Thanks Justin but I need 6 so Ollie can grab them if he wants them.
Sent from my CLT-L09 using Tapatalk
Current system:
RPi + Allo Digione
Beresford Caiman Seg & Dorado powered by 15v Linear PSU
Transcendent Sound Mini Beast OTL
Amptastic Mini-1
Klipsch KG4.5 Speakers with Titanium Diagphrams and Sonicap Cap upgrade
110aH Leisure Battery powers the Mini-1 & Digione
What suggestions for the internal wires? Copper / silver / Teflon coated Thickness?
Current system:
RPi + Allo Digione
Amptastic Mini-1
Yeah the prob is the one I've liked the most so far is has a cheaper SA in it than the one I'm building.
If I knew for sure that a dcb1 would work in my system I would have a go at bulding one but I don't so I'm not going to risk it
I couldve splashed out more on the SA I suppose but the last time I did that it didn't work out too well. Possibly picked the wrong type of khozmo there and didnt give it long enough burn in time.
I can always switch bits out of this pre once it's together.
Current system:
RPi + Allo Digione
Amptastic Mini-1
Oh go on then if you insist..... Sure you won't miss it? Ha ha
Current system:
RPi + Allo Digione
Amptastic Mini-1
Oliie I couldnt borrow your DCB1 off you even if you was happy for me to.
Anyway today my SA has turned up so just waiting on the rca sockets now and I'll be under way.
Current system:
RPi + Allo Digione
Amptastic Mini-1
Rca sockets turned up too. Not solid gold like Ollies but 24c gold plated and should do the trick nicley..
Anyone after cheap gold plated rca sockets should take a look at 'that's audio' on ebay. Got 3 pairs for £8 delivered. Good value in my book.
Current system:
RPi + Allo Digione
Amptastic Mini-1
