Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Sanding birch ply.
    Default Sanding birch ply.
    Guys,
    I like to sand some rough edges from birch ply. I have a belt sander in the workshop. I'd really like some suggestions for the best type of belt to use on the sander so the I can sand a rough edge piece of birch ply into something nice and straight.
    Thanks
    Andy
    PRE
    I'm jamie.
    the best advice i can give is use a plane,i wouldn't sand an edge to get it straight with a belt or any other sander to be honest
    My System
    John Wood KT88 Amp.
    Paradise Phono Stage
    Sony TTS-8000 Turntable.
    PMAT-1010 MK6 Tonearm.
    Ortofon Cadenza Bronze
    Sony X555ES Cd Player
    Yamaha NS1000m Speakers
    If just light sanding I'd be inclined to do it by hand or with a block. Electric sander might dig in a bit quick.
    Very fine hand plane would work too
    I'm AndyElectroNumpty.
    Router with edge guide?
    At the cutting edge of Numptyness!
    I'm Deleted.
    Planing plywood is likely to result in a lot of broken grain at the edges. Belt sanding it can easily lead to heavy grooves at the end of the belt. Hand sanding is just impractical unless the edge is already pretty straight. By far the best solution is to take it to someone with a table saw and it will be staright and square in seconds with only the lightest sanding required.
    Account Deleted
    I was assuming it was fairly straight.
    I'm jamie.
    not if you come in from both ends
    My System
    John Wood KT88 Amp.
    I might end up just buying a table saw. I'm going to experiment tomorrow at work.
    PRE
    I'm Deleted.
    Quote Originally Posted by karma67 View Post
    Sorry, but no, irrespective of which end you come at it from (even both simultaneously) - because it is ply! The very nature of ply is that the grain of each layer is at ninety degrees to the other, which means that no matter what you do you are always planing across the end grain at some level.
    Account Deleted
    I'm gordan.
    truly wondering how people make this:
    Gordan.
    Speakers: Oris Swing MkII
    Amps: Thomas Mayer 300b/ Hiraga La Maison de L'Audiophile 20
    Preamp: Silver AVC by eng. Ferenc Lazar
    Phono Preamp: Shishido LCR by Solaja Audio
    Decks: Garrard 301 Martin Bastin reworked/plinthed with Fidelity Research FR64fx
    Garrard 401 in eng Ferenc Lazar solid wenge plinth with SME 3012/2
    Cartridges: SPU Spirit/ Koetsu Black revisited by eng. Salai/ Miyajima Shilabe
    Step Up Transformers: Tango MCT 999/ Ortofon T-5000/ Lumiere SUT
    Digital: Shigaclone by eng. Ferenc Lazar with Lampizator Amber II
    Wires: of sufficient length
