Results 41 to 49 of 49
Thread: My kitchen renovation
  1. #41
    I'm Gary.
    Thank you, it's getting there
    Marantz CD63 KI Signature
    Project Debut II
    Pioneer A656 Reference
    Epos M5s
    Atacama Stands
    Maplin speaker cable cos I can't hear a difference
    Various interconnects as above
  2. #42
    I'm Gary.
    Still plenty to do
    Project Debut II
    Epos M5s
    Atacama Stands
  3. #43
    I'm Gary.
    I've been taking up the old floor tiles in the hallway and found beautiful old flagstones underneath
    Annoyingly at one end they're covered with levelling compound that is bonded so well that I can't remove it without damaging the flagstones
    Project Debut II
    Epos M5s
    Atacama Stands
  4. #44
    If it's epoxy based levelling compound or of any other synthetic base, paint stripper should make it removable. If it's water based, it's likely of an alkaline material and acids like vinegar or loo descaler will loosen it. From the photos, the flags look like sandstone or York stone.
  5. #45
    Best bet is to lift them and turn them over imo. that stuff doesnt come off well.
    Could work, but natural stone is often rough finished on back and not necessarily symmetric, so may not fit turned over. I used to lay the stuff.
  7. #47
    yup agreed.. might be worth a look tho.
    I can't tell from the picture but if the leveling compound is at the front door end, how about creating some kind of wooden threshold area incorporating a door mat or something just to hide it?
  9. #49
    I'm Gary.
    Thanks for the suggestions but sadly, due to time constraints, I'm going with the original plan and tiling over them, much as I hate having to do so.
    The levelling compound is cement based and although only a few mm thick I can't remove it without damaging the flagstones.
    It's criminal covering them but I only have 3 days off work to get everything finished
    Project Debut II
    Epos M5s
    Atacama Stands
