Hi all, im using a Radford sc22 but it sounds bright and bass light through the phono stage, i have tried an external phono stage and it seems ok, also ok on cd, any ideas as to why the built in phono stage sounds like this, thankyou, regards, peter
I'm peter.
I'm peter.
Hi volume seems ok
Stupid question but you're using the disc input? Volume would be low if you weren't.
There's plenty of possible reasons but one simple thing worth checking is there's a preset gain control for the phono stage internally
Sent from my ONEPLUS A5000 using Tapatalk
