Don’t make life complicated...
Just download Net Analyzer on your phone and get the Volumio network address.
Type that in manually.... that’s it!
I'm Peter.
I'm Colin.
I think the first issue is I am not seeing raspberry pi so something not right. I may just try moode . I suppose this is why I quite like cd and vinyl it’s such a slick effortless system
I'm Peter.
Don’t give in my man!!
Volumio does it all.... you don’t need to try anything else.
All the Pi is looking for is a network address.
Typing it in manually will work. But you have to know what it is first!
Try it!!!!!!
If pi is connected to same router it should show.
Check volumio set up. Maybe redo the card. It should set up straight away. Takes about 2 mins to start up
I'm Peter.
Agree..... this is not rocket science.
It just an address of the Pi connect to Volumio, (it will be 168.192.0. “A number “)
I'm Peter.
Come on Collin, do it for me......
Streamed music tonight..... is the prize.
I'm Colin.
Won’t give in but will leave for tomorrow. Thanks for help.
I assume your iPad is connected to the network. Also worth checking if there aren't 2 channels on your WiFi my BT router has a 2.4ghz and 5 GHz or something, a device connected to one can't talk to one connected to the other.
I'm Peter.
