Was thinking of some kind stress relief where the wire meets the enclosure. Maybe some sort of metal wire I can wind around each of the 6 wires and then attach to the inside of the box out of sight. Something like that anyway.
Current system:
RPi + Allo Digione
Beresford Caiman Seg & Dorado powered by 15v Linear PSU
Transcendent Sound Mini Beast OTL
Amptastic Mini-1
Klipsch KG4.5 Speakers with Titanium Diagphrams and Sonicap Cap upgrade
110aH Leisure Battery powers the Mini-1 & Digione
You can get gripping cable glands (a sort of grommet). Or, you can use ordinary grommets and put a small zip-tie round each cable inside the case to stop it pulling through.
Thanks all. Got some cable glands.... silver solder..... A dale SA and an Ali Express case on order. Once its arrived I'll start a new build thread with some pics for anyone interested.
Sent from my CLT-L09 using Tapatalk
Current system:
RPi + Allo Digione
Amptastic Mini-1
Any channce of a link to the case you bought as I am considering making a one in one out little unit but would like it to look okay .
Andrew here's the case I've bought:
https://m.aliexpress.com/item/330433...A1568485514370
Current system:
RPi + Allo Digione
Amptastic Mini-1
