Results 1 to 10 of 14
Thread: Gyrodec motor repairs
    I'm Ian.
    Default Gyrodec motor repairs
    I think my Gryrodec motor has dried out, the spindle is very difficult to get going after it hasnt been used for a while. Once I have freed it up using my fingers it works ok until it hasnt been used for a while.
    Sent an enquiry to Michell but no reply. Anyone had a reliable repair done elsewhere?
    oil maybe gone gunky. try cleaning it out and replacing fluid.
    OPPO BDP-103D - PANASONIC UB450 - IFI PURIFIER 2/PATHOS CLASSIC REMIX & HIDAC AMPLIFIER - LEAF HD BLUETOOTH - NURAPHONE' HEADPHONES - 2*ZBOOK'- ROON - MULTI HDD'S - DIGIONE RPI3 - EDINGDALE MK1 SPEAKERS - CABLE INC SUPRA, FISUAL, MOGAMI,
    **I’ve studied deeply in the philosophies and religions, but cheerfulness kept breaking through**
    "An old man sleeps with his conscience at night, while young kids sleep with their dreams"
    "Justice is sinking to the bottom of the sea, And it feels like I'm living in the wasteland of the free"
    It was the weakest practical joke since Cardinal Wolsey got his nob out at Hampton Court and stood at the end of the passage pretending to be a door!
    “I like my whisky old and my women young.” – "Happiness is having a rare steak, a bottle of whisky, and a dog to eat the rare steak!"
    I'm Ian.
    The motors stiff, not the platter
    I'm Gary.
    Ian,
    Is your motor silver?
    If so, I have a spare I'd sell.
    *will be perfectly fine..*
    I'm Ian.
    Gold
    I'm Justin.
    Phone them up. I've had a couple of chats with them in the past.
    I'm Simon.
    If it's the Papst motor with the external flywheel they can be stripped down, cleaned up and work like new again.
    Best of luck
    SJS Arcadia Line Level Pre-amplifiers, Headphone amps, MM Phono Stages and SET Power amps - service, repairs, upgrades
    I'm Ian.
    Heard back from Michell, £54 inc vat and return postage.
    Motor removal is pretty simple, disconnect mains power. Undo allen bolt on top of motor cover, lift up motor and cover place on its side next to platter. prise the rubber/felt washer off the top of the power input socket and slide up the cable that goes to the motor. MAKE A NOTE OF WHICH CABLE GOES WHERE. cut or unsolder the 3 power cables lift off and remove outer case.
    Removal looks as if it will be more diffcult because access to the power socket cables for resoldering is restricted. The arm board assemby and platter will probable need to come off
    I'm Deleted.
    An unusual problem because turntable motors rarely dry up/seize in the manner described. Is your turntable motor near a radiator or often in direct sunlight?
    Account Deleted
    I'm Ian.
    Actually I think michell could be held liable, the qc psu if left on dries the motor out. I found out the hard way but the damage was done
