Results 1 to 3 of 3
Thread: USB to DAC setting
    I'm William.
    Default USB to DAC setting
    Hi Guys
    I’m looking to be able to increase the output of of jriver meadi centre 23 to my DAC.
    When I use a web radio page say jazz24 in Seattle the volume through the DAC is louder than when I use jriver. When I use jriver I have to turn the amp volume up.
    I have looked in many of the settings in jriver adjusted a few but it doesn’t seem to work the web radio is always louder.
    I just get the feeling that I’m not driving the DAC with the max signal and therefore not getting the best out of it.
    Many thanks
    tools, options, dsp and output, parametric equalizer, add, adjust vol, enter a value... you can add several and only the ticked one/ones will be used. handy for quieter media
    I'm William.
    Thank you so much
    Worked like a charm.
    Have a good weekend
    Regards
    Bill
