Results 1 to 8 of 8
Thread: Valve advice needed
    Default Valve advice needed
    Hi All.................I recently mistakenly bought a NOS pair of Siemens PCC88 valves. I have some source items that use 6922 and /or E88CC
    One item is my Audiomeca CDP another is a SWIX DAC 1.
    How does the PCC88 differ and can it be substituted for the above
    Tangerine LP12,Naim Aro, Benz Wood
    Hovland HP100 MC
    SiriuS D100
    Quad FM4,RWA Cassabria + LCD 3
    Wilson Benesch Actors
    The PCC88 has a slightly higher heater voltage of 7.6V as opposed to 6.3V of the others.
    If you try it it will probably work to an extent but the heater will be under run and is not recommended.
    Aha Thanks Alan
    Hovland HP100 MC
    SiriuS D100
    Quote Originally Posted by ovlov854 View Post
    Aha Thanks Alan
    Funny I've seen it said that this will prolong their lives! Although now I think about it, it's usually the sellers that say this!
    Hi Martin
    If in doubt about the SW1X DAC I would drop Slawa an e mail - he may even recommend a substitute that can improve performance.
    SW1X USB II
    SW1X DAC III Special
    SW1X Open Baffle Speakers containing both vintage and modern alnico drivers and paper cones. All silver wired and crossover-less where possible - 4" vintage Siemens Klangfilm tweeters, 8" Supravox 215 RTF64 vintage midrange drivers and vintage 15" Altec VOTT 416 bass drivers
    Hi fi Collective twin mono ladder stepped attenuator, with Charcroft Z-foil and silver wired.
    DRD 45 single ended, 45 triode, monoblocks,
    Up to 10% is the maximum without affecting performance or spoiling the heater efficacy, so 7.6 - 10% = 6.84V. 6.3 is just too low.
    Hi Martin
    Hi Chris
    Yes I did get in touch with Slawa and he did reccommend a heavyweight version of the Russian E88CC he supplies and I've got one.
    Only problem is that I mixed up the 2 of them and now I can't tell which is which
    I do have a number of 88 variants which I can use (currently a Brimar) but hoped to be able to use the PCC88 as a pair in my other CDP when my CrossedSwords Teslas give up
    I did find that the Russians were very detailed but overly bright for my taste
    Hovland HP100 MC
    SiriuS D100
    Whatever the theory I've run PCC 88s on 6.3v perfectly satisfactorily for a long time circa 5 years with no ill effects. So if you've got a pair, and you like the sound what's not to like? You won't harm your equipment
    Sent from my ONEPLUS A5000 using Tapatalk
