Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: FS Luxman AT-3000 TVC
    I'm Rohan.
    Thanks for the update , my Dac has an internal resistor based volume control that can be bypassed so i would like to see if i can improve the sound with a very good active or passive preamp.
    Dac T+A DSD8. Roon/HQ player
    Amplifier 2A3 set
    Speaker full range Fertin lb12EX
    I'm Adrian.
    Here's my experience using a number of valve amps including my superb Audio research 75 as well as most all types of passive.
    You cannot beat an autoformer (AVC not TVC) for transparency and all that brings (timbre etc) but it's a gamble with valve amps. There's a reason I'm using a valve pre at the moment and won't go back to a simple passive, drive and frequency are much better, an oh my god moment, in fact. However I will be replacing the standard alps pot with a tribute autoformer in the near future so I have the absolute best of both worlds.
    The Slagles equal the Townshend and in my opinion the Music First stuff. You can buy a ready built dual control for around 300 dollars direct, super simple to wire up (even I could do it!) and you can go as crazy as you like with an enclosure. It will at least tell you if your amp is okay with this type of passive for little cost.
    A Luxman normally goes for around 2k so is a very expensive way to go, but is a statement, masterpiece in its truest sense and cannot lose value.
    But here's a suggestion...
    Get the Slagles or keep an eye out for a second hand tribute (they are AVC) and with the extra savings buy the best quality tube buffer you can get to put before the AVC using the shortest possible cabling. This will in effect give you the necessary gain, beauty of tube swapping and tuning your sound as well as transparency and nuance. I highly recommend the Eastern Electric Minimax BBA which has adjustable gain and responds very very well to tube rolling. But with this you will probably follow my path and then swap out the Alps for an autoformer for that final level of transparency.
    Adey
    Sent from my Aquaris X Pro using Tapatalk
    Technics SP10 mk2
    Miyajima Shilabe cart
    Hashimoto HM-X SUT
    The Truth linestage
    Cary 805c SET amps
    Audio Note ANe-SPX speakers
    I'm Rohan.
    Thanks for your point of view , i already had few passive preamp with TVC and AVC , ( bent audio noh with S&B tvc , promitheus Tvc, bent with slage Avc modules, and the tribute autoformer.
    For my taste the Big S&B Tvc was the most musical that’s why i was interested by the luxman.
    I have some 26 tube to spare to make a tube preamp perhaps with a autoformer but with the time î’m getting lazy
    Amplifier 2A3 set
    I'm gordan.
    why not updating your signature?
    Gordan.
    Speakers: Oris Swing MkII
    Amps: Thomas Mayer 300b/ Hiraga La Maison de L'Audiophile 20
    Preamp: Silver AVC by eng. Ferenc Lazar
    Phono Preamp: Shishido LCR by Solaja Audio
    Decks: Garrard 301 Martin Bastin reworked/plinthed with Fidelity Research FR64fx
    Garrard 401 in eng Ferenc Lazar solid wenge plinth with SME 3012/2
    Cartridges: SPU Spirit/ Koetsu Black revisited by eng. Salai/ Miyajima Shilabe
    Step Up Transformers: Tango MCT 999/ Ortofon T-5000/ Lumiere SUT
    Digital: Shigaclone by eng. Ferenc Lazar with Lampizator Amber II
    Wires: of sufficient length
