Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Thorens TD 125 Problem
    I'm Glen.
    Phew! Looks like it’s all sorted! I cleaned out the green gunk and until the oil I’ve ordered arrives, I’m using some light oil from the local petrol station. It’s now running very well. I did the spin test again and it went for over 2 minutes... result. Thanks again Struth.
    Good it's working. Sounds like there's been a reaction in the well. Maybe an engine oil been used. They work for a while then cause corrosion as there are additives in them for engine cleaning etc. Be OK for a short time tho
    If the TT is running slow, how come the stroboscope indicates the correct speed? Or do you mean the TT takes a long time to reach the correct speed? If the latter, then clean out the bearing well and replace the oil. A new belt may also help.
    A well maintained TD125 ought to reach the correct speed (according to the strobe) within one revolution of the platter.
    Oops - seems you have already found the problem. Well done!
    Even so, I would use the correct oil which can be obtained from Schopper in Switzerland. They are experts in the maintenance of vintage Thorens TTs. https://www.schopper.ch/index.php?pa...125-spareparts
