Page 6 of 8 FirstFirst ... 45678 LastLast
Results 51 to 60 of 75
Thread: Dehumidifier Magic!
  1. #51
    My de-humidifier has arrived. Not the same as Jim's but very similar, also works as an air purifier. The fancy humidity monitor arrived earlier in the week, it shows time, temp and humidity. Currently running at 21.3 degrees and 64 percent. Will get the machine running in a bit and see what sort of impact it makes.
    You will be doing well if you get humidity down to 60%. Don't forget to close all windows and doors!
  2. #52
    My windows are hardly ever open anyway! Even in summer. The noise from the street irritates me. As soon as I open a window some fucker in a diesel will pull up outside and sit there for half an hour with his engine running.
    Anyway I'm aiming for the golden 55% humidity, see if it can be done.
  3. #53
    I wonder if a dehumidifier would speed up the drying of my undercrackers on the clothes maiden?
  4. #54
    I'm Dennis.
    In your position Martin I would seriously consider the effects of that environment on my health.
    In '86 I, as a result of a split-up had to move to a studio flat on the Borough High St., and the pollution there was very bad, but I had previously rebuilt an ioniser and I put it into service.
    I also had lent it to my Mother who lived in Beckenham, and who smoked a lot, and when I went to see her I could see what looked like marmite running down her walls, such was its effectiveness.
    When I finally left the Borough in '94, when I moved the furniture the walls were black with exhaust and wheel disc wear, and I recommend anyone in such to get one; a small investment for a major gain in health IMO.
  5. #55
    Ioniser seconded.
    Mine is an air blown jobbie so the filter is cleaned every so often.
    Stunning the amount of muck I clean out of it
    Mike
  6. #56
    My humidifier has an ionizer. I've not fou d any muck so far but I don't smoke so maybe the reason
    I already have an ionizer but thanks for the suggestion.
    Pollution is not really a problem although the air quality round here is not great. It's more the noise that makes me keep the windows shut.
  8. #58
    I'm Craig.
    Stop Press!
    Hifi stores inundated with requests for dehumidifiers! ��
    Bluesound Node 2i
    Audio Analogue Pucinni SE
    B&W DM607 s2
    Klotz ic’s
  9. #59
    Okay dehumidifier update.
    With it running for about an hour I can get humidity down to 53%. I have 3 humidity meters, one built into the unit, a stand-alone digital temp and humidity monitor and an old fangled analogue job and they all read the same. After an hour there was about an egg-cups worth of water in the tank.
    With no dehumidifier running the humidity varies from 55% to 65%. This appears to be entirely dependant on the weather. This morning humidity is 57% without the unit running. Conclusion: I don't have a humidity problem in my house. Although the unit I bought also acts as an air purifier so there is some use to it. I have not found there to be any connection between the humidity and sound quality, possibly because I cannot get the humidity high enough to hear any deleterious effects.
  10. #60
    humidity is 51 here.. not had my humidifier on of late as its been humid enough. but with winter onsetting they will be on a lot more
