Oh, be quick too as if you have the traffo wired wrong, you could burn it out very easily and that's not a cheap fix, as you know
ok thanks , will do tomorrow now cheers mate
Sent from my SM-G975F using Tapatalk
At the cutting edge of Numptyness!
Also, do one winging at a time.
If you have the 909 wired right, it should read 9v on either side of the 0 and 18v if you measure the two outers.
Don't have the 165v wired up at all. Just separate the wires and secure them in connector blocks. Does that make sense.
If the 909 is right, you can then measure the 165v
Yes that make sense cheers
Sounds like you have some sort of short on the 165V winding. Check you have the rectifier diodes the correct way round and also check for shorts with the soldered joints to the ground plane.
Thanks Alan will do , you mean these 4?
Yes Andy. With the 165 voltage being pulled down so much there must be a fault in that area.
Ok will check the tranny and then the soldering underneath for potential shorts. Thanks for the help
Got distrated and doing some case work. But once the switch etc is fitted it will make it easier to test so no loss there . lol
