Results 1 to 10 of 13
Thread: Blu ray player with optical in
    Default Blu ray player with optical in
    Hello, wasn't sure whether to put this here or the AV bit so feel free to move mods is there a good 4k blu ray player with optical in? Ta Jim
    I'm AMusicFanNotAnAudiophile.
    I strongly doubt it.
    Chris
    Common sense isn't anymore!
    It would be useful just for feeding the TV through it , I know some CD players have this option, ah well
    I take it you have a DAC to which your current BDP is connected.
    Chris
    Well it's not something I currently need as my TV is fed throught my novafidelity x40 but I'd like to go back to CDs at some point and don't really want a stand alone dac, thought it wouldnt be the end of the world
    Your Nova has a Toslink input.
    Connect your TV to it.
    Hook the BDP up to the TV using HDMI, and use the TV as a switching hub into the Nova.
    Chris
    Oh yes I know, the novafidelity is my digital hub, but at some point I'd like to go back to a CD player , and so just wondered if a blu ray player with optical in was an option
    Is it not possible to play a CD directly in the Nova?
    Chris
    It is, and I have to say I cant fault the sound and the convenience of the novafidelity, how ever I've never been keen on slot loading players, I know I'm being picky but what can you do
    Buy a CD player with a tray and hook it up to the Nova with either a coaxial SPDIF cable or a set of analogue interconnects.
    Chris
