Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Has anyone made a grounding box?
    I'm Josie.
    Default Has anyone made a grounding box?
    Hi all.
    Just interested in these grounding boxes... not sure if they are total foo.
    But the prices are astronomically high so I wondered if anyone had made any which they think work?
    Thanks
    TRIO L-07D Turntable - Tube Distinctions Copper Amp (Using KT150's) - Croft Epoch Elite (Very highly upgraded) - Studer A80R Master Recorder (High Speed 15/30 IPS) - 15" Tannoy Monitor Gold - Loudspeakers in Lockwood Major cabinets - Tannoyista SPEC 3 Custom Crossovers - VanDamme Black Speaker Cable - Allo KATANA SQ + SHANTI psu
    I'm Oliver.
    I put Alan's (one of the coherent ones) in my system and the sound stage collapsed.
    Had a totally negative effect in my system, yet appears to make a good contribution to his system.
    50/50 in my opinion.
    I'm Mark.
    There was a massive thread on AoS about them not that long ago.
    100% Analogue
    I'm AnDreW.
    Oh No, not this subject again.
    CD Teac VRDS25X(Audiotuned) DAC Caiman SEG+15V PSU+Dorado DECK 1210 Mat Crystal Audio Mods MN Base/Bearing/Platter+Ebony armboard Feet Isonoe/Ebony PSU Paul Hynes SR7EHD-27XL/DCSXL Ag DC lead/3 Stage Regs/Recap PCB+No Pitch/Strobe/Light ARM SME V(Kondo Ag Rewire&Tags) MC Cadenza Black FGS CABLES Arm Yannis SPD-4 IC Yannis 222 Litz+Ag bullets Power WAR PRE ATC SCA2 SPEAKERS ATC 50ASL STANDS Atacama PHONO Sugden Masterclass PA4 SUT Ortofon ST80SE POWER PSAudio P10
    PRE
    Croft Epoch(Modified) AMP Sondex S100 (Modified) SPEAKERS Tannoy 15"MG+RFC Warwick cabs+ Reference XO DECKS Garrard301/401 (Bastin) Mat Teunto Bearings 301/401(Bastin) Plinth Moldovan/Bastin Arms 3009/3012(Ikeda Ag wired) SME V 12 PSU Eagle+Tachometer MC Ag Meister v2 / Royall N SPU's CABLES Arm Yannis 420.5 Litz+ Speaker 10mm Cu + WBT-0681 Ag IC Oyaide FTVS-510 AgWBT 0110Ag Phonostage Paradise(4 Box Modded) / EAR 834 Clone (modded)
    REAL SOUND
    PRE Radford SC25 (Mullard ECC83/82) POWER RADFORD STA25 Renaissance (Electroharmonix EL34) SPEAKERS Celestion Ditton 15 (Duelund Rewired/Jantzen Recapped) CABLES Speaker - Duelund AWG 12IC - Belden 8402+Switchcraft RCA
    Yup. It was proved that nobody can prove what it does, if anything!
    "when common sense, logic and plausibility are excluded. All that remain are foolishness and lies"
    I'm Ian.
    Cats been using them for years
    Turntable
    CD
    Network Player
    Cambridge NP30
    Amplifier
    Speakers
    Cables
    Headphones
    Littering threads with bad jokes again?
    https://youtu.be/NOVfFLTXB3k
    I bought some bits for this, cigar box, copper plate and wire, some rca plugs and some litz silver wire. Got derailed researching the minerals and then i used the litz for an earth strap on a network switch instead.
    Tourmaline quartz and rochelle salt are 3 of the minerals in his box. The minerals donít come cheap and its hard to guess amounts.
    Happy to sell on bits if anyone fancies taking it the whole way.
    I'm Josie.
    Aahh.. Yes... LOL - I forgot about that EPIC thread.
    They do seem to be getting more popular since I first looked years ago.
