Results 21 to 30 of 50
Thread: Garrard 301 bearing upgrades??
  1. #21
    I'd be very interested to hear from anyone who has installed the CTC bearing and brass platter, or indeed the similar Peak ones - I understand that they used to come from the same supplier but don't now. I think CTC can also do a bronze one which is probably more comparable with the Shindo but that is a "special order" item. I'm trying hard not to spend any money on hi-fi at the moment or I would be able to report on these myself.
    David Whistance
  2. #22
    I'm Karl.
    I think the CTC platter is only 7mm diamter larger so hardly noticable to look at and works fine with a normal bearing, whereas the shindo ones looks really big(too big for my tatses) and probably needs a bigger bearing to cope. Lots of happy reviews with the CTC platter so it must have some merit ???
    CTC Classic 301 , SPH bearing and Hanze Hifi HAT CPS-2 all analogue power supply / Tenuto Mk2 mat / custom Panzerholz and Kewasinga articulating plinth / Track audio isolation feet / Reed tonearm / Audio Technica ART 9 / 2 box BigBottle mk3 phonostage with Clarity cap CMR and NOS Telefunkens valves / Croft 25R preamp with upgraded 12BH7A line stage and NOS 1956 RCA valves / Croft 7R monoblocks with NOS 56 RCA valves/ Dynaudio Contour 30i speakers / Spotfire interconnects and speaker cables / Merlin Scorpion mains block / Rhodium mains cables / Marantz CD DAC /
  3. #23
    Quote Originally Posted by Bigbird View Post
    buy a 5mm tenuto gun metal platter mat you'll get the same results. It's just extra mass and inertia, or fit a 401 motor To your 301 for more torque, swings/roundabouts et al.
    PRE
  4. #24
    Umm I am pretty sure it is not that simple...And moving mass is not the same as mass alone.
    I guess the oversized platter will have a significant amount more inertia than just the additional weight that the Tenuto will have...I am sure someone with more maths/physics knowledge than I can explain better...
    As for the motors the grease 301 are meant to have a significant amount more torque than the 401 models. If I understand correctly its the shielding that the 401 models improved on.
    (Ive just had my 401 Audio Grailed....And have been bothering Matt with a long list of questions...)
    StSt Motus DQ + SME 312 'MB Special'
    Transfix Axia / HM7
    Art Audio Vinyl 1 Ref
    Modified Mac Mini/Weiss DAC 202
    SJS Model 2
    BP P20 (SJS upgraded)
    Trenner and Friedl RA
    [/SIZE]
  5. #25
    Quote Originally Posted by Mike Adams View Post
    Your probably correct TBH I think we are going around in circles (like a platter)!
    PRE
  6. #26
    I'm Karl.
    Default Garrard 301 bearing upgrades??
    Has anybody tried a power supply with theirs? Have read that by lowering the voltage to the motor on the power supplies that you can reduce motor vibrations and noise and improve speed stability , bringing positve results ??
  7. #27
    I'm Clive.
    Has anybody tried a power supply with theirs? Have read that by lowering the voltage on one of the power supplies that you can reduce motor vibrations and noise and improve speed stability , bringing positve results ??
    Been there....reducing voltage is attractive at first, I used a Variac but then I realised dynamics reduced.
  8. #28
    Been down the reducing voltage route. All you need to get the best from a 301/401 motor is a very clean power supply going in. I use a PS Audio P10. Secondly a decent tachometer for platter speed stability I use the Phoenix PSU + Tachometer. No buggering around with variacs, DIY PSU's, fitting light bulbs. If you think your getting vibration from the motor into platter, decouple it.
    PRE
  9. #29
    I'm Adam.
    Had very positive results using a variac on my 401, no loss of dynamics. Took the voltage from 256v to 220v...
    A great tweak for relatively small financial outlay.
    "lack of passion is fatal"
  10. #30
    I'm Karl.
    Thanks guys lots to research and think about. As always with hifi, lots of conflicting views. I was kinda hoping thered be more concrete views on certain products so i could narrow down my options.
