Results 1 to 7 of 7
Thread: FS Impulse Lali
    I'm Rich.
    Default FS Impulse Lali
    Unfortunately I need to downsize, so most of my current kit is going. Starting, very sadly with my much loved Impulse Lali loudspeakers.
    They are in really nice condition over all, I've tried to capture any dinks a clearly as possible, the worst mark faces backwards on the inside of the wooden fascia and isn't as noticeable from the front as it looks in the pics. There is a dink or two to the glass plate on the tops of both speakers, but again this really doesn't look as bad as it does in the pics (in my opinion). I shall see if I can find the terminal links, I'm sure I have them but I have never used them, Van Damme jumper cables will be included if wanted. One bolt appears to be missing from the plate of the terminals on both speakers, I've never noticed that before so I can't offer an explaination as to why, but I'm trying to describe them as honestly as possible so I wanted to mention it.
    This pair has matching serial numbers, and a bit of googling shows they date from the mid 90s with a sensitivity of around 91db. I've owned them for around 5 years and they have given me huge amounts of pleasure.
    Collection only I'm afraid, but who ever buys them gets a cuppa and a biscuit.
    £625 but would be happy to take a pair of small bookshelf/standmount speakers up to around £250 in part trade (active or passive)
    Clearaudio Emotion with Clearaudio Performer cart
    Copland CDA 266
    Copland CSA 28
    Squeezebox Touch
    Impulse Lali
    Van Damme I/Cs and cables
    I'm Phil.
    Love the varnish finish on those , the marks are easily repaired as the baffle is solid wood . hope someone buys these soon as they are super speakers
    Eric Bibb
    I'm Rich.
    Quote Originally Posted by hifinutt View Post
    Thanks Phil. Yep, they are very good looking speakers, a bit of thought went into the design.
    Copland CDA 266
    Copland CSA 28
    Squeezebox Touch
    Impulse Lali
    I'm Rich.
    Simon, can you make space in your inbox please? I'm getting a can't be delivered message, due to capacity.
    Copland CDA 266
    Copland CSA 28
    Squeezebox Touch
    Impulse Lali
    I'm Simon.
    Done
    I'm Rich.
    Quote Originally Posted by Daisy View Post
    Done
    Full again by the look of it
    Copland CDA 266
    Copland CSA 28
    Squeezebox Touch
    Impulse Lali
    I'm Rich.
    I appreciate collection only is a pain, so hopefully a price drop might help.
    Now £595.
    Looking for a pair of standmounts in part ex if that helps.
    Copland CDA 266
    Copland CSA 28
    Squeezebox Touch
    Impulse Lali
