Results 1 to 10 of 16
Thread: Van Damme 2.5mm Blue Studio Speaker Cable
    I'm Shane.
    Default Van Damme 2.5mm Blue Studio Speaker Cable
    Been using 2.5mm Blue Studio for a year now. These are great cables and for the money, very hard to fault.
    Might think about going up to the larger 4.5mm Blue Studio. If anyone has gone over to the 4.5mm, please share your results. Good/Bad etc.
    Thanks.
    S.
    Shane Lonergan.
    I'm jamie.
    try the hifi grade ,it just good quality ofc copper,i went from 4mm to 6mm and thought the bass improved.
    My System
    John Wood KT88 Amp.
    Paradise Phono Stage
    Sony TTS-8000 Turntable.
    PMAT-1010 MK6 Tonearm.
    Ortofon Cadenza Bronze
    Sony X555ES Cd Player
    Yamaha NS1000m Speakers
    I'm Shane.
    Quote Originally Posted by karma67 View Post
    Link please.
    S.
    Shane Lonergan.
    I'm jamie.
    My System
    John Wood KT88 Amp.
    I'm Shane.
    Thanks, Jamie.
    S.
    Shane Lonergan.
    I'm jamie.
    how long do you need? ive got some 4mm you can try if you like?
    My System
    John Wood KT88 Amp.
    I'm Shane.
    I'm in no rush yet, Jamie. Just thinking about it for now.
    S.
    Shane Lonergan.
    Good cable but try this at 10mm diameter at the fraction of the price. It's now in my systems.
    https://www.autoelectricsupplies.co....66/category/11
    PRE
    I use short lengths (< 1 metre) of either Van Damme 4.0mm2 or 6.0mm2 speaker cable.
    Years ago I looked at using heavy current duty automotive cabling, but could not satisfy myself that the quality of the copper used was sufficiently good.
    I'm Phil.
    use both 2.5 mm van damme and 6mm van damme studio , i can`t find a huge difference though . pretty happy with the 2.5mm . since it costs peanuts its no harm to try
    Eric Bibb
