One of the channels has started emitting that high pitch sound, so would need some EL34 valves.
Don't need to be matched. I can take 5, reasonably priced.
I'm martin.
I have 8 Russian Svetlanas ( I note you said 5) for £10 each, or 4 Svetlana Winged C's for £20 each, plus postage
I'm martin.
Thanks, I'll check them out and get back.
I can recommend the Marshal branded valves from Watford Valve pretty much as decent as almost any of the new production out there at a bargain price
https://watfordvalves.com/product_detail.asp?id=5640
Interesting. I would suggest that they would be a very good buy at the price.
I'm George.
There are a lot of good comments on the sound quality of the TungSol 7581As which for a lot of EL34 amps it is a straight swap. Although it is best to check with the manufacturer. They are about £19 each.
http://www.hotroxuk.com/tungsol-7581...ed-valves.html
