Sound any good
Sound any good
This Luxman kit has changed my mind about solid state gear.
So yes it is very good, Grant.
Interestingly it can run two sets of RCA out at different volumes.
Further thoughts when I have spent more time with it.
The circuit board traces are not allowed to form straight edged right angles.
Check it out.
https://images.app.goo.gl/k8Hdr4CPuV5kYnKMA
Justin, back to your vibration testing and microphonic valves, you might want to try some of these out https://www.ebay.co.uk/itm/4-x-SORBO...oAAMXQrhdTWUIF, they are relatively inexpensive, just select the right size for the weight of your Lampizator. I think you might be surprised by how effective they can be, I use some with my ALLNIC 300B and with the Voyd TT, mainly as I don't want to spend hundreds on isolation platforms. The other option I have tried which works well is a marble chopping board sat on the sorbothane feet and then the equipment onto the marble. I did this with a Gyrodec, known for poor isolation and prone to vibration transferral through the feet to the chassis etc., it made quite an improvement IMO.
Thanks but see post #13 I did manage to get much better isolation from the maglev feet.
Sorry missed that, might be interesting to try out though and see what you think.
Found it.
Seems there's only reason for it in high current circuits and that's to prevent arcing across the angle.
