Results 1 to 10 of 16
Thread: Garrard 301 DRD
    Default Garrard 301 DRD
    Anyone got a clue what the triangular bit is over the bearing ?
    PRE
    Could we have a better piccie please?
    Dave
    That's all I've got.
    PRE
    Hi Andrew
    This might be a little better
    [IMG][/IMG]
    Turntable; Rega p8
    Cartridge; Alpheta mc
    Amplifier; Rega Elicit
    Speakers; Rega Rx3
    Thanks Steve. I think clicking on the attached picture I included should go full screen.
    PRE
    I'm TAD.
    is this an ex BBC item ? I have a pdf of a 301 Service manual from 1961, but no specific mention of this triangular part. unlike any 301/401 I've ever seen. regards. T.
    Quote Originally Posted by TAD12 View Post
    Yep its a heavily modded BBC model. I'm thinking the triangular part might be a bearing collar, it's over the spindle so I wonder if it's designed to stop "give" developing in the spindle. The DRD models had many modifications over the standard 301. I'm looking into previous models and seeing what I can use to improve my 301.
    PRE
    I'm mark.
    AG will know for sure, but my thoughts are a crude system for a 2nd platter to cue records like the Thorens 124. I've seen mechanisms underneath that lift and lower the main bearing to engage a top platter?
    * wrong triangles!
    The bearing in the picture has been modded from grease to oil bearing, does the 'new' triangle help maintain oil reserve with a felt washer underneath for prolonged use?
    Quote Originally Posted by DiveDeepDog View Post
    * wrong triangles!
    Good points Mark, I forgot out the cueing system. You've got good eyes, I had now idea the bearing had been modded!
    PRE
    I'm mark.
    I thought the oil bearing a standard upgrade by the BBC, involved filing the chassis to make them fit though.
    My own Grey 301 was allegedly ex Lancaster BBC but is untouched.
    I was able to make the SPH bearing fit without touching the chassis.
