Page 4 of 4 FirstFirst ... 234
Results 31 to 35 of 35
Thread: Anyone else using Exact Audio Copy to burn CDs onto a hard drive?
  1. #31
    I'm Edward.
    Thanks Edward.
    Last time I looked (and I'm fairly sure it was within the last couple of years, although it could easily have been longer) it wasn't supported.
    I've just done some WAV ripping using dBPoweramp, and I can read tags using Mp3Tag.
    Cool huh!
    Pity that EAC has not been updated since about 2015 and hence does not include this functionality. But it is real easy to run MP3tag over ripped wav files especially if artist and album details are present.
    In the past I did extensive testing between flac and wav (and alac a bit) and honestly did not determine much difference (if at all) between them in terms of sq. Some people do.
    JRiver has a neat feature whereby you can take a lossless file (e.g. wav) and it will downsample a snippet to various different resolutions and then will play them back 'blind'. The user then selects what s/he thinks it is and a score is given at the end. An interesting excursion into self embarrassment.
  2. #32
    I'm AMusicFanNotAnAudiophile.
    I can't hear a difference between the WAV files I just ripped and the FLAC compressed ones.
    I'm going to stick with FLAC.
    It makes for more efficient transmission over the network, and the storage requirement is less.
    I have used the blind testing plugin in Foobar a few times, and it's brought some interesting results
    Chris
    Common sense isn't anymore!
  3. #33
    I'm Paul.
    Just for completeness....
    I use either 'asunder' or 'sound juicer' to rip CDs (running in linux) to flac files. They both get the meta-data over the network, but asunder sometimes finds the data when sound juicer dosn't.
    I hear no difference in sound quality.
    khozmo passive pre/nytech ca252/cxa252 amps, arc 101 speakers
    vinyl: --- lp12/kore/lingo4/ekos2/dv 10x5/gs accession
    digital: --- caiman SEG/allo digione, synology nas, rotel 965 cd
  4. #34
    Ive noticed since last update of JRiver25, it is now using a secure rip system similar to EAC. much slower and comes up with a dialogue re how it ripped each track etc.
    Ive not found any info re this but thought i'd mention it. Thought my drive was faulty at first it was ripping so slow in comparision lol
    I'm Neil.
    Default Anyone else using Exact Audio Copy to burn CDs onto a hard drive?
    Yup, I ABX tested FLAC and WAV using some STAX electrostatic ‘phones. Zero difference, and man I did try to find some. Also tested FLAC vs “LAME Insane” 320kbps CBR and did notice a very small, but worthwhile difference: a touch more air and space with FLAC.
